oil leak
Old May 2, 2013 | 02:16 PM
pure1959's Avatar
oil leak
Well, just done a load of work on the 89 z28 305ci, new paint, new drive gear for speedometer, and other stuff. car repays me by getting an oil leak out of the rear crank seal! the car is stock and has its factory motor, my quetion is, in 89 is the 305 fitted with a two piece crank seal or one piece?
Old May 2, 2013 | 06:59 PM
ex-x-fire's Avatar
Re: oil leak
Stock89 engine should have 1 piece rear main. If it is the rear main, you'll have to pull both the oil pan & tranny.
Old Jun 23, 2013 | 05:25 PM
vertigo1202's Avatar
Engine: L98 TPI 5.7L 350
Transmission: 700R4 Automatic
Re: oil leak
Hi, you sound like you know what youre talking about. I have an issue where i revved very high at park, and oil began leaking from somewwhere behin the intake manifold. i had just redone the gaskets as well as the rtv on the both ends yesterday so i figured they had time to cure. wondering if you can point me in some direction. p.s. the oil looked milky brown. thanks.
88 trans am gta L98 350
Old Jun 23, 2013 | 05:38 PM
ex-x-fire's Avatar
Re: oil leak
There's an oil pressure sending unit back there, get a flash light & look closely.
Old Jun 24, 2013 | 06:03 PM
Re: oil leak
thanks. im sure thats it.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
