89 formula 350 - freaks out when warms up
Old May 3, 2013 | 06:25 PM
89FormulaMan's Avatar
Hello,
got this problem out of no where. when my car gets warmed up, it starts to bog out and the RPM's jump and the car stalls out and runs like crap. once the car cools off, it starts right up and runs normal again until it heats up. i just noticed that the 2nd fan of the car is now turning on so i don't know if one has to do with the other. can anyone assist? PLEASE!!!!!!!!!!!!!
Old May 3, 2013 | 06:53 PM
ex-x-fire's Avatar
Re: 89 formula 350 - freaks out when warms up
Need more info,, tbi, tpi, carb, ect.
Old May 3, 2013 | 10:19 PM
350 TPI fuel injectio. just as an FYI, the problem started just after I had the pass side header gasket replaced. Dont know if that was just a coincidence or not.
Old May 3, 2013 | 10:22 PM
350 TPI fuel injection. just as an FYI, the problem started just after I had the pass side header gasket replaced. Dont know if that was just a coincidence or not.
Old May 3, 2013 | 10:40 PM
ex-x-fire's Avatar
Put a fuel pressure gauge on it when its acting up.
Old May 4, 2013 | 01:31 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Ohm injs when cold then warm.
check fuel psi.
Check ign modual.
Check pickup coil.
Check coil.
check MAF.
Old May 5, 2013 | 11:28 AM
a62belair's Avatar
Car: 88 Firebird, 87 Formula
Engine: 2.8, 5.0
Transmission: both 700R4
Axle/Gears: 3.42,3.45
Temp sensor still disconnected, broken?
Old May 5, 2013 | 03:43 PM
check fuel psi.
Check ign modual.
Check pickup coil.
Check coil.
check MAF.
Ok, sounds like a plan of where to start. Most appreciate the response
Old May 5, 2013 | 03:44 PM
this is on the pass side by the header right? if so, it is still connected. I dont know if the secondary fan not working has something to do with this issue?
Old May 12, 2013 | 09:07 PM
mene0013's Avatar
I have the same issue. 88 350 tpi stock. When the car warms up it sidles high (1000rpm in park). Temp sensor is new, fuel filter is new, fresh oil change done, etc
Old May 12, 2013 | 09:33 PM
conlinj's Avatar
Most likely bad injectors
Old May 12, 2013 | 09:54 PM
conlinj's Avatar
I think he means the ECU temp sensor which is on the front of the intake manifold under the thermostat area. The one on the passenger side controls the secondary fan only. There is also another temp sensor on the driver side between 1 and 3 that is for the gauge.
Old May 12, 2013 | 10:25 PM
Yes, the one on the pass manifold controls the secondary fan. Do you know which of the 5 relays in the car control that fan? that is the one that I need to check to see why it is not activating. Also on a side notes, I had bad fuel which is why the car was running like crap. All injectors had 17.8 ohms
Old May 13, 2013 | 12:12 AM
conlinj's Avatar
pretty sure on my formula its on the passenger side next to the radiator.
Old May 13, 2013 | 12:17 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I wonder if someone swapped the knock sensor plug with the coolant temperature sensor between cylinders 6 & 8.
Old May 13, 2013 | 04:10 PM
I see 2. one on the radiator itself and another by the air cleaner on the pass fender. Those were the 2 that I checked first.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
okfoz
Convertibles
83
Oct 29, 2018 11:18 PM
okfoz
Mar 9, 2017 02:35 PM
Linson
Aug 31, 2015 04:52 PM
