SBC rail rockers
Old May 9, 2013 | 07:34 PM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
SBC rail rockers
So, the '87-up self-aligning rocker arms: do they all have the same slot length? I just put a fresh .466-lift cam in, and some of the rockers seem to dislike more than a half turn of the nut past feeling drag while spinning the push rod. Watching the push-rod cups of the lifters shows they're all moving off the snap ring a little bit, but some of them will, when on their base circle opposite the lobe, will let me push down with my thumb on the push rod cup of the rocker, and some will not. I'm afraid those that will not are going to need swapped before reinstalling the intake manifold and valve covers?
Old May 9, 2013 | 08:25 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: SBC rail rockers
sounds normal to me. you should be good as long as the slot doesn't hit the stud before full lift..
Old May 9, 2013 | 09:49 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
The lifters have just bled down, as they will do with no oil pressue. They'll come up hard against the snap rings again once the engine is running.
Old May 10, 2013 | 08:08 AM
cosmick's Avatar
It's the other end of the slot that I'm worried about. One of my friends called one of his friends, and I now have 8 more rockers to try. I'll measure the lengths of the slots and report back.
Old May 10, 2013 | 08:19 PM
cosmick's Avatar
I found 3 differences of appearance, so I checked 2 of each. They all checked between 0.6195" and 0.6205". So I buttoned it up, here's hoping I don't bend any push rods.
Hotrodboba400
Dec 10, 2019 07:07 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
New2Chevy
Sep 28, 2015 12:35 AM
BOOT77
Sep 5, 2015 03:55 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
