HT817 Lifters?
Old May 10, 2013 | 10:31 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
HT817 Lifters?
I have a new in box cam and I was wondering, are these lifters any good? I found them on Summit's website.
Old May 11, 2013 | 08:31 AM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: HT817 Lifters?
A friend and I just installed a set of those in his 350, along with a Summit 1103 cam. Hoping to first-fire the engine this evening to break-in the new cam / lifters. We used COMP lube instead of the black moly paste, he bought a 5-gallon jug of Quaker State Defy oil with ZDDP in it, and I poured in a small blue bottle of STP additive with ZDDP. Planning on 1500-2000 RPM for 15 minutes, varying the RPM constantly. I'll report back if we wipe a lobe or dish a lifter crown. Or both.
Old May 14, 2013 | 06:36 PM
cosmick's Avatar
Re: HT817 Lifters?
First-fire got interrupted by fuel-delivery problems, but even so, break-in went well, steady vacuum gauge reading, runs strong, sounds as it should. I'd call these lifters good enough, so far.
Old May 15, 2013 | 12:48 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: HT817 Lifters?
Stock replacement SFederal Mogual/Sealed Power lifters.
Fine for a mild rebuild.
Soak them in fresh oil overnight before installing helps.
Old May 15, 2013 | 04:40 PM
cosmick's Avatar
Re: HT817 Lifters?
Dunno about the OP's application, nor your definition of mild, but I must call these results "performance" rather than "stock".
Old May 15, 2013 | 04:50 PM
Car: 1971 Camaro
Engine: 427
Re: HT817 Lifters?
Not sure what results you are talking about.
Those are stock replacement lifters.
Sure they can work in nonstock applications, but they are likely to pump up in a high rpm application.
tyeo098
Nov 30, 2015 06:27 PM
codeysabatini
Nov 10, 2015 04:07 PM
skinny z
Oct 5, 2015 06:23 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
dimented24x7
Sep 6, 2015 03:51 PM
