engine dies
Old May 11, 2013 | 01:44 AM
built's Avatar
Car: 82 TA
engine dies
I am having a problem with my 82 TA ,305 HEI dist.quadrajet.
I can be driving along fine and then it will just quit running and will not restart right away, sometimes not for hours. I have tried jump starting it when it quits and that is no help.
what can I test or is this something thats common and there's no need to test just replace something now.
Old May 11, 2013 | 07:07 AM
Damon's Avatar
Re: engine dies
That sounds like something ignition-related. Flaky module or coil being the usual suspects.
You can rule out fuel issues if the next time it happens you have a can of starting fluid in the car. Give a shot in the carb and immediately try to start it. If it fires up for a second and dies again, you have fuel-related issues. If it doesn't, it's ignition.
Old May 11, 2013 | 08:10 AM
ryanz281988's Avatar
Car: 1988 z28 camaro
Re: engine dies
whens the last time you changeded you spark plugs, spark plugs wires, cap and rotor and hopefully its not your distributor thats a pain.
Old May 11, 2013 | 08:46 PM
built's Avatar
Car: 82 TA
Re: engine dies
Its been awhile since I have replaced all the ignition parts but wouldn't it run rough or idle rough if wires or plugs were bad?
Is there anyway to test the module and coil ?
If the module is going out would it act this way?
I guess same for the coil,I mean is this a common symptom ?
Old May 12, 2013 | 07:45 PM
Damon's Avatar
Re: engine dies
I wouldn't call it a common symptom, but it happens. Electronic parts hate heat. Sometimes they have issues when hot that don't crop up when they are cold. Modules and coils can be bench tested with the right equipment, but I've seen as many times as not that they test good but are still bad in an actual running engine.
eightsixseven
Dec 16, 2024 01:50 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Andrew6.688
Dec 13, 2015 10:59 AM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
