Help!! Car is stranded and wont start!
Old May 12, 2013 | 06:27 PM
Soon2beBad91Z28's Avatar
My 91 camaro died while i was driving it today. I pulled over and could not get it to start. I have spark, but I believe that there is a problem with fuel delivery. I can hear the pump prime half the time and it sometimes starts but soon dies. It doesnt have enough gas being pumped. is it a bad fuel pump or relay? Or something else? Should I bypass the relay to see if it will work?
Old May 12, 2013 | 06:34 PM
Lakerman62's Avatar
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
Re: Help!! Car is stranded and wont start!
Does it try to start but not turn over? Had similar issue, thought it was fuel pump, ended up being the coil. Best wishes.
Old May 12, 2013 | 06:57 PM
i shot starter fluid in it and it fired up no problem, i hear the pump prime half the time
Old May 12, 2013 | 07:21 PM
I should clarify that it was running fine earlier then just got weird and shutdown. now it acts like it doesnt have enough fuel and dies
Old May 12, 2013 | 10:27 PM
almost made it home but still having difficulties, the pump randomly turns off
Old May 22, 2013 | 05:44 AM
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
Hmm If the pump randomly turns off, Thinking fuel pump relay?
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
L98GTA87
Aug 5, 2015 11:02 PM
