vss wiring for electric speedo.
Old May 18, 2013 | 07:28 PM
direngrey's Avatar
vss from trans (purple yellow) to c100 pin d4 and e4 to connect to
Purp yellow on buffer box. I dunno why speedo won't work there is contenutity all the way to the vss purple yellow wires.
87 v6 to lg4 swap. Cable v8 trans swapped vss from v6 trans. All my electrical is working in the car except my speedo .
Anyone have any ideas ?
Old May 18, 2013 | 08:31 PM
Vader's Avatar
Re: vss wiring for electric speedo.
Refresh my memory - Did the '87 Camaro have a VSS buffer box? Firebirds did, but there were differences across the years.
Old May 18, 2013 | 08:35 PM
direngrey's Avatar
Firebirds were 87 I think camaros went electric in 89
Old May 18, 2013 | 08:38 PM
Vader's Avatar
BTW - If the original speedo had a cable, you'll still need one to make it work. The VSS signal generator hanging off the back of some Camaro speedos was only to signal the ECM and cruise. The speedo in those wasn't electrically operated. If that's your case, you may need to swap in a cluster from a later Camaro. IIRC, '89 and later had electric speedos.
Old May 18, 2013 | 08:40 PM
Vader's Avatar
Actually, my '86 TA is electric. I believe they were electric in at least '85. Also, if the Camaro is a Berlinetta (not your '87) it would also have an electric speedo.
Old May 18, 2013 | 08:46 PM
direngrey's Avatar
My firebird is electric speedo. Trans had cable I took vss and but it in the trans. Have it wired to the box speedo doesn't work.
Old May 18, 2013 | 09:15 PM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
85 is the last year for the mechanical speedo in the firebird.
You can test the VSS to make sure it is sending a signal by using a volt meter in AC mode. It should produce voltage when you spin the VSS by hand or with a drill.
Also you can test the connection between the buffer box and the speedo. It is pin 14 on the bottom connector of the gauge cluster.
You can also technically hook the vss up directly to the gauge pin 14 to make sure the gauge works properly. Just hook one wire to ground and the other to the wire that goes to the gauge. If the VSS and gauge both work then you know the buffer box is bad.
Old Dec 16, 2019 | 06:21 PM
AustinHealey's Avatar
Hoping someone can answer this.. picked up a low mileage 89 trans am and the odometer does not work but speedo does.. I noticed the cover under the passenger compartment was ajar is there any wiring issues that could cause that symptom to occur..
Old Dec 16, 2019 | 06:48 PM
direngrey's Avatar
I'm pretty sure the little plastic gear on the back for the odometer breaks if you take out cluster and take out the speedo see if the gear is broken
Old Dec 16, 2019 | 07:21 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/inte...roken-but.html
Old Dec 16, 2019 | 07:28 PM
OrangeBird's Avatar
Car: 1989 Firebird
.. picked up a low mileage 89 trans am and the odometer does not work ....
Hmm , , , maybe not as low mileage as you may think ?
t-top havoc
Mar 11, 2012 12:07 PM
Superkop
Feb 1, 2011 09:18 PM
unklechuckles19
Sep 7, 2005 05:53 PM
devianb
Jun 2, 2005 03:28 PM
john5.7 87Iroc
Oct 8, 2003 10:35 PM
