fire hot 355 help.
Old May 22, 2013 | 10:34 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
fire hot 355 help.
Well recently this week like Tuesday my Buddys truck caught on fire. He had just put a rebuilt 355 flat tappet motor in with a decent sized can not even 600 miles ago. How the fire started is that the carb backfired through the carb and caught the air cleaner on fire while it was running and proceeds to burn down the whole truck. Would the motor still be reuse able if I went through and did a new gasket kit through the whole motor? I could get it for $150 but don't want to jump on it before I do
Old May 23, 2013 | 06:28 AM
1gary's Avatar
Re: fire hot 355 help.
With that kind of fire anything under tension(valve springs/rings),and seals,tolerance is gone.
Old May 23, 2013 | 12:19 PM
bwiencek's Avatar
Car: 1984 TA - 17k orig miles
Engine: 355
Axle/Gears: 3.44 Dana 44 performance rear
Most of it should be re-useable if the engine stopped running before it got too hot. I'm guessing that it didn't get hot enough to melt the throttle body? (or carb?) If so then you should be fine. I'd pull the engine apart, pull the heads apart, clean everything (or have a shop tank it). If it didn't melt the valvecover rubber gaskets (assuming that it's a centerbolt vc) and especially melt the PCV grommets then the valvesprings didn't get that much heat and I wouldn't worry about them too much - if they were melted test them and replace if necessary. Once everything is cleaned put on new valve stem seals, and then assemble with a new gasket set and prime it like a new engine and run it... Should have no more than $100 more into it for a gasket set and a set of flat tappet valvesprings...
Old May 23, 2013 | 09:10 PM
Engine: L31 350
It melted the holley or atleast the fuel bowls
Old May 23, 2013 | 09:28 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
did the front tires of the truck burn up completely and does the engine still have oil in the pan? a mild underhood fire is enough to melt the carb a little while doing little damage to the engine "long block"
Old May 23, 2013 | 10:31 PM
Engine: L31 350
The front tires popped but didnt melt. You can tell it was a decent fire because the paint burnt off the hood and it did shattered the glass and the interior
Bubbajones_ya
Jul 6, 2024 08:32 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
tommy z-28
Oct 6, 2015 10:58 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
Ranbo108
Sep 9, 2015 12:20 PM
