FireDemonSiC
close
Just got done assembling my new ac system. Right now it has the stock white Orifice tube but I have seen people talk about using an orange or blue tube.
Right now the system has not yet been charged vaccumed down so it wouldn't be a problem to swap for a different tube.
I was just wondering what if any benefits would a different type of Orifice tube provide.
sofakingdom
close
- Join DateSep 2005
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- CarYes
- EngineUsually
- TransmissionSometimes
- Axle/GearsBehind me somewhere
- Liked:2,485 Times in 1,897 Posts
The orifice tube sets the flow rate of the refrigerant, and thus a whole laundry list of compromises; high-speed vs low-speed cooling, head pressure vs efficiency, and so on.
The white tube is correct for R-12 in a GM R-12 system. The others give better performance with R-134A in a GM R-12 system. They simply work BETTER, all around. More suited to the evaporative properties of the different chemical.
FireDemonSiC
close
Which one would you recommend and what vehicle could it be looked up under?Originally Posted by sofakingdom
The orifice tube sets the flow rate of the refrigerant, and thus a whole laundry list of compromises; high-speed vs low-speed cooling, head pressure vs efficiency, and so on.The white tube is correct for R-12 in a GM R-12 system. The others give better performance with R-134A in a GM R-12 system. They simply work BETTER, all around. More suited to the evaporative properties of the different chemical.
sofakingdom
close
- Join DateSep 2005
- CarYes
- EngineUsually
I usually use the red/orange one. Fits Frod; ask for like a 96 Crown Vic.
I've been told the blue one works well also but I've never tried it. Don't know exactly what Frod it fits.
FireDemonSiC
close
Many thanks! I still have to replace the high side schrader valve so I will swap it at the same time.Originally Posted by sofakingdom
I usually use the red/orange one. Fits Frod; ask for like a 96 Crown Vic.I've been told the blue one works well also but I've never tried it. Don't know exactly what Frod it fits.
