Fuel Filter backwards?
Old May 30, 2013 | 02:46 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
How do I tell if a universal fuel filter is installed backwards? I mean, the one I have IS marked IN and OUT, but what if some jerk in Hong Kong assembled it backwards?
I have a fuel pump, compatible with the Bosch 0 580 254 044, which is supposed to be good to 72 PSI. I can't even get 10 PSI out of the thing (and that's with a fuel pressure gauge I know to be accurate as I used it on the other fuel rail... Not the one mounted to the AFPR). Fuel lines are brand new, fuel fittings are brand new (and I finally got the leaks out), fuel rail is nearly empty. I have no pressure. The only thing I can think of is that the fuel filter is backwards and the pump is trying to force fuel past any possible anti-drainback valve that might be in the filter...
Old May 30, 2013 | 02:52 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fuel Filter backwards?
If you look into the filter on the inlet side there is a block 1/2 in down so the fuel will be forced through the media. on the outlet you can see all the way down to the plug.
Old May 30, 2013 | 07:19 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Never mind... I looked up the actual real instructions for a similar Aeromotive regulator and found out I had the AFPR hooked up backwards (hooked up the out as the in and vice versa). I suppose that's what I get for buying a kit that doesn't come with any instructions . The FPR is set to 50 PSI now and I have no external leaks that I can see (after I tightened each and every fitting on the pump's outlet between the pump and the solid line!).
Now if I could just figure out the following 2 issues, I'll be set:
1. Why I can't get a pressure reading at the Schrader valve on the fuel rail (unless my gauge has gone bad while sitting)...
2. Why the system won't hold pressure when the pump shuts off. Hopefully the high flow pump will help this, but it still bugs me...
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
