1 pc rear seal to 2pc rear seal flexplate?
Car: 1986 Iroc-Z
Engine: 5.7
I'm working on a 1986 chevy camaro and I'm dropping an older style 70's 2 pc rear seal 350 in it. I'm not sure but I am under the impression that I cannot use the flex plate and starter from the 86 305? I hope so because I was planning on using most, if not all the parts off of the 305 to swap over to my 350.
Re: 1 pc rear seal to 2pc rear seal flexplate?
Right: cannot use the flex plate. Get one for 83-85 V8 Camaro/Firebird.
You can use your starter if your block has both holes that it needs. (blocks from before about 78 probably won't, 78-up probably will) If not, you can have your machine shop drill it for you.
84z96L31vortec
Aug 20, 2017 12:16 AM
Dialed_In
Aug 20, 2015 01:45 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
