just picked up an LT1 intake manifold- what could/should i do with it?
Old Jun 2, 2013 | 07:03 PM
Bobby Goff's Avatar
Car: 86 Camaro Z28
Transmission: TH 700R4
I picked up an lt1 inbtake manifold and a spare throttle body for it at the junkyard, what can be done with it for cheap? it doesn't have the injectors or fuel rail-just the aluminum intake with throttle body... i like my tpi but i had to get this just in case i move up to a 350 or 383 anytime soon (i have 305 now )
Old Jun 2, 2013 | 07:41 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: just picked up an LT1 intake manifold- qhat could/should i do with it?
You'd spend more to modify the intake then buying an aftermarket one.
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Sell it for scrap metal, or start modifying it for coolant cross over and a dizzy.
Old Jun 2, 2013 | 08:38 PM
Bobby Goff's Avatar
Car: 86 Camaro Z28
Re: just picked up an LT1 intake manifold- what could/should i do with it?
does it have to have the coolant crossover in front and back? (i assume it does).. any good tech articles on it?
Old Jun 2, 2013 | 08:44 PM
DukeofHurl's Avatar
Car: 1986 Z28
Engine: 350 Q-Jet
Personally I wouldn't worry about having an LT1 intake just yet for just in case I end up with a bigger motor. I'd just put it on Craigslist and try to make a buck or two from it. Don't want to rain on your parade but if you are still working with the 305 and wanting to go bigger I'd put my money into another motor. Once you are there and you want a better intake then you should be looking at this type of thing if not just going with an aftermarket bolt-on setup.
Old Jun 2, 2013 | 08:49 PM
Bobby Goff's Avatar
Car: 86 Camaro Z28
looks like what i'll be doing, that or ebay i suppose.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
zayne0
Aug 24, 2015 07:22 PM
sreZ28
Aug 14, 2015 07:48 PM
