Flexplate to flywheel
Old Jun 3, 2013 | 04:12 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
So I'm in the middle of my 383 build and my rotating assembly came with a flexplate. This is an int/ext balanced rotating assembly (hence why it came with a specific flexplate).
My problem is that I'm using a manual trans (t5, also built by me) so i need a flywheel. This is a SCAT 9000 rotating assmebly and i am unable to get in contact with scat (called and emailed multiple times) to ask which flywheel i should use. On their website they dont sell flywheels, only flexplates and balancers. So my questions is, what the hell do i do?
Do I find out which is the right balancer from scat to use? and use a neutral balance flywheel (Again, i cant get in contact to get this information from them)
Or do i buy a flywheel from somewhere else thats balanced right and get a neutral balancer?
This engine is already built besides oil pan and distributor/wires. So the last thing i want to do is have to rip it apart to get a flywheel balanced to match the rotating assembly.
Also, any difference with balancing an engine with a flywheel or with a balancer/damper?
Old Jun 3, 2013 | 04:23 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Flexplate to flywheel
Make it internally balanced with Mallory slugs
Old Jun 3, 2013 | 06:18 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Like i said, I have everthing except the oil pan and distributor/wires assembled. I DONT want to take it apart to have the crank balanced.
Old Jun 3, 2013 | 06:20 PM
Engine: Lb9
Transmission: M20
GLWT
Old Jun 3, 2013 | 06:49 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by NagleMac
i need a flywheel. Do I find out which is the right balancer from scat to use? and use a neutral balance flywheel
You don't state if it is 1 pce or 2 pce RMS; a more important factor in determining the correct version
No such thing ;
it is either internal balance or external ( 400 ci crank based )
All internal balance engines use a neutral balancer ; only the external balance 400 crank based assembly uses a weighted balancer .(EXT balance at both ends )
Part # ?
Old Jun 3, 2013 | 07:02 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
I haven't ever seen a true internally balanced motor from GM; any flex plate from any motor has always had some sort of weights on it.
Old Jun 3, 2013 | 07:27 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Google GM part #14085720 , 3991469 or 471598
True neutral balance wheels for 2 pce RMS SBC with no weights
Old Jun 3, 2013 | 09:15 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Its a 1 piece rms, and the part description states "int/ext" balanced. 942-1-91100BIE
thats the part number. This kit comes with a flexplate but the other its dont come with a flexplate or balancer or anything. I know i can get a neutral weight balancer, but i need a flywheel of the correct balance. A 400 flywheel would be correct? or no because this is an aftermarket piece? Can i bring my flexplate to a shop and get a neutral flywheel balanced exactly like the flexplate?
Old Jun 3, 2013 | 09:30 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Its a 1 piece rms,
Your 1 pce RMS crank only takes 1 pce RMS flywheel which has a balance weight on it.
A 400 flywheel will be wrong balance and even if it was correct , it would not bolt up to your 1 pce crank
Whether your assembly is balanced to stock factory balance ( in which case you can use any off the shelf factory style flywheel ) or has been custom balanced is a different story.
You buy the correct 1 pce RMS flywheel , like one of these ( has to be 153 tooth to suit your T5 )
http://www.summitracing.com/search/p...tity/153-tooth
and take it and the flexplate to shop so they can compare the balance
Incorrect naming by the maker which leads to the INT/EXT balance confustion.
Thje 1 pce RMS Flexplate is externally WEIGHTED ; not externally balanced
Old Jun 3, 2013 | 09:51 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Got it. So the easiest thing to go is get a flywheel, bring it to my machinist and have him compare the balances. If they are different then he can weight the flywheel the same as the flexplate and stick with a stock neutral balancer.
Old Jun 3, 2013 | 10:00 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Got it.
As I noted , only a 400 based "383 " crank has a weighted balancer ; all other SBC balancers are neutral , regardless what the rear crank arrangement is
Stangski09
Nov 14, 2015 01:27 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
