Serpentine belt being torn apart...
Old Jun 8, 2013 | 10:14 PM
Lmancha96's Avatar
Car: 1992 Camaro (Z28 Clone)
Engine: LB9|TPI
I have gone through two belts In the past couple of hours I replaced the first one and drove for about 10 minutes before it tore again...
It was making a very loud squeaking noise the entire time I drove.
I noticed this ?pulley? is not moving when the car is on and it seems to be the problem
any input will be highly appreciated.
Thanks!
By the way the car is a 1992 Rs Stock 305
Attached Thumbnails Serpentine belt being torn apart...-img_0219.jpg   Serpentine belt being torn apart...-img_0216.jpg   Serpentine belt being torn apart...-img_0217.jpg
Old Jun 8, 2013 | 10:37 PM
danclemts's Avatar
Car: 1985 Volvo turbodiesel
Engine: 1989 305 TPI in the Volvo
Transmission: 1990 700r4
Axle/Gears: 3.73 Dana 30
Re: Serpentine belt being torn apart...
That's the tensioner idler pulley, should spin very freely. if it is locked up, you can buy a new one at any auto parts store for 20.00 or less, one bolt in the middle holds it on. I just replaced mine a couple of weeks ago. the new one won't have the raised edge, just a flat pulley, will work fine.
Old Jun 9, 2013 | 09:32 AM
Lmancha96's Avatar
Engine: LB9|TPI
That did the trick. Thanks!
jrdturbo
Mar 31, 2016 02:58 PM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
SRKLEGIN
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
