Rear main bearing cap
Old Jun 6, 2013 | 02:58 PM
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
Hey guys its me again with yet another question. I am taking my short block apart to get cleaning at a machine shop and I am in the process of removing the main bearing caps. I have removed all except for the rear main bearing cap, the one the oil pump mounts to. This one is being a real pain to remove unlike the others and I was wondering if I was doing something wrong? Maybe there is another way it must be removed instead of prying it loose?
Old Jun 6, 2013 | 03:11 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Rear main bearing cap
Caps can be a pain to get off. Is this a 2 pc rear main block? The rear main seal is usually installed with some silicone around the split line join which can seep into the bearing cap splitline and kinda glue it down. May have to try prying loose gently. I smack mine with a rubber mallet to kinda budge it loose
Old Jun 6, 2013 | 03:37 PM
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
Yeah I believe it is a 2pc rear seal. Its a 010 block and those were in production until 1980 i believe so it would be a 2pc rear seal. I just wanted to be cautious because I was always told that if something would go, don't force it.
Old Jun 6, 2013 | 04:22 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
Just use a rubber mallet or deadblow hammer. You'l get it off without damaging it that way.
Old Jun 6, 2013 | 05:56 PM
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
Hmm ill have to try the rubber mallet in that case. Thanks again guys.
Old Jun 6, 2013 | 06:28 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Rubber mallet? Way too gentle. I use my brass hammer.
Old Jun 6, 2013 | 07:54 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Brass works too
Old Jun 7, 2013 | 06:35 AM
Or, a REAL MAN'S BFH, with a block of wood as padding.
Old Jun 7, 2013 | 07:35 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
I use the bolts for leverage.
Pull them out and pull them sideways to pop the cap loose.
Old Jun 8, 2013 | 11:01 PM
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
Thanks for the fast responses guys. Finally got that stubborn thing off and got the engine sent to a machine shop. Now I just have to hope that the starter on the old engine will work on the new one going in.
Old Jun 8, 2013 | 11:05 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Depends on bolt pattern, fitment if youre using headers, and the compression ration of the new engine.
Old Jun 8, 2013 | 11:08 PM
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
Yes very true, I had a 305 in my 86 iroc, now the block I am using for my rebuild is a 010 block. I hope everything lines up, If not worse case scenario I just have to buy a new starter?
Old Jun 8, 2013 | 11:28 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Im not sure what the bolt pattern on that block is, but if this is a performance high compression eninge then youll need a new one, or a mini starter if using headers. They arent that expensive
Old Jun 8, 2013 | 11:33 PM
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
Hmmm Not sure, I do know that the engine has flat top pistons and I am using a set of 601 heads on the 350. So I may need a new starter anyways.
Old Jun 8, 2013 | 11:39 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Id get one either way, itll be worth it
Old Jun 8, 2013 | 11:40 PM
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
True true, thanks for all your help!
Old Jun 9, 2013 | 09:58 AM
"Hope" is not a very effective plan.
Be smart: have the hole drilled that your block is probably missing, BEFORE dropping the motor in. Best to have it done while it's getting bored etc. and is already at the machine shop.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
LT1Formula
Aug 20, 2015 09:36 PM
86White_T/A305
Aug 17, 2015 12:16 AM
