KEY WON'T TURN it's stuck in the lock position
Old Jun 11, 2013 | 04:55 PM
Vinscully50's Avatar
Car: 1986 Camaro IROC Z
Engine: LB9 305 TPI
When I put my key in the ignition it will not turn, It is stuck in the lock position. My car is all the way in park, my foot is on the brake and it will not turn. I have been fighting with it all day, and I have tired turning the steering wheel and that has done nothing. What could be the problem?
Old Jun 11, 2013 | 06:34 PM
Snoopywasaga's Avatar
Car: 84 camaro Z28 LG4
Engine: 305 LG4
Transmission: 5 spd BW
Axle/Gears: stock
Re: KEY WON'T TURN it's stuck in the lock position
If it's not stuck because of the steering wheel cranked over too far it's probably your key is worn down or the cylinder itself. Sometimes cutting a new key from the old one can help.
Old Jun 11, 2013 | 07:03 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
grab the column right by where it goes under the gauge cluster- the outside part actually turns a little bit as some sort of a pointless safety interlock mechanism with the shifter..
Old Jun 14, 2013 | 01:58 PM
Engine: LB9 305 TPI
Looks like it was the wheel, I kept fighting with it and finally got it to come lose. I have driven the car several more times with no more key problems.
Derick15
Sep 17, 2016 05:28 PM
Jae992
Aug 27, 2015 09:07 AM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
BrianI
Aug 9, 2015 11:52 AM
