Smog pump only makes noise after warmed up = bad check valves?
So my smog pump only seems to make noise after my engine gets warmed up. (and no it's not getting masked by other noises). And I just noticed, that's when I start to smell more exhaust gasses too. The noise seems to get slightly louder the longer the engine runs too.
I know bad check valves will lead to a bad smog pump, so I'll probably still replace the smog pump, but would this tend to indicate the check valves are bad?
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Smog pump only makes noise after warmed up = bad check valves?
theshackle
Sep 17, 2020 08:26 AM
db057
Aug 11, 2015 10:11 PM
