Smokes at start and smells {New Engine}
Old Jun 6, 2013 | 01:13 AM
Noodles's Avatar
I just got a jasper 5.0 engine installed recently about 2 weeks maybe and I've had no real complaints except i have noticed that some white smoke comes out of the exhaust on start ups and there is somewhat of a gas or some kind of a smell im not sure every now and expectantly at WOT. Im getting about 13.5 mph idk if that is a clue. When i took a look at it the other day i saw the vacuum hoses weren't fully on it and it did run a bit better. I think its just running rich but I'm not sure. Im going to be taking it to the shop some time next week. Thanks for any clues.
Old Jun 6, 2013 | 01:19 AM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
Re: Smokes at start and smells {New Engine}
possibly a cracked head leaking water into a piston and just smokes at start up???
Old Jun 6, 2013 | 08:42 AM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Lets start with the color of the smoke and what it smells like. Is it oil or water?
Generally a brand new motor will smoke because the rings haven't seated.
Old Jun 6, 2013 | 10:02 PM
Noodles's Avatar
the smoke is more like blue smoke and the smoke smells like oil i would say, every now and then like on idle at a stop light i smell a little gas. how long does it take for the seals to set?
Old Jun 11, 2013 | 09:45 AM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Sounds like burning oil. The gas smell is from running rich completely independent from the oil.
Breaking in the motor all depends on driving style. Generally after 2 or 3 tanks of fuel it is broken in for the most part. Make sure you don't run it at the same rpm for a long period of time.
Old Jun 11, 2013 | 10:19 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
A new or freshly painted engine getting warm is a good smell lol.
If its real lean or rich *sounds like rich* something different
Double check your tuning FP etc to make sure all is right
If so load that puppy up with some WOT runs then decel a number of times
when you get 50 mi on it drop the hammer..not saying redline it but drive it a little hard and youre broken in.
Old Jun 12, 2013 | 11:38 PM
Noodles's Avatar
Im smelling oil just about every time i go WOT. Is that normal? Ive put about 700 miles on the motor. I haven't really noticed the smoke on start ups except maybe once or twice. I check the engine oil level just about every day and its right under the full line so its not burning like crazy.
Old Jun 13, 2013 | 06:24 AM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Originally Posted by Noodles
Im smelling oil just about every time i go WOT..
Significant oil odor at WOT suggests blow-by emissions.
Check the PCV valve.
Old Jun 13, 2013 | 09:12 AM
1gary's Avatar
Stop messing with it yourself and take it to a Jasper installer to be evaluated.
bryan623
Mar 22, 2021 06:43 PM
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
