Alternator/Starter need Guidance
Good day all. 91 Z28/L98 TPI street strip car, battery is charge but now when i went to start it the other day it seems the alternator just clicks and I can see it move (1/2") that's it, no cranking its is fairly new (alternator). So i was thinking it maybe the starter. My money pit
Thanks evey one for aby info
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: Alternator/Starter need Guidance
If the battery is charged and the solenoid on the starter just clicks then it's probably your starter. Pull your stater and have it checked at Autozone for free if you can't get the car started. If you can get the car started, have the alternator, battery, and starter checked. Good luck.
wigmobile
Feb 26, 2025 02:56 PM
