camaro not cracking plss help
Old Jun 18, 2013 | 06:37 PM
chevyman559's Avatar
So i have a 91 camaro 5.0 manual. I replaced the block and when i was ready to start she wouldnt cranck or click. I checked battery , battery cables, and starter; they checked out good. I replaced starter switch and cheked the voltage on purple cable going to starter and only have 5 volts. Also when i turned the key i dont hear the fuel pump. I wonder if its the key switch... please help.. thankx
Old Jun 18, 2013 | 06:57 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: camaro not cracking plss help
There is only one IGN switch that has power through it which is located at the base of the steering column; is that the one you replaced?
If not, possible that is faulty and not passing power or has no power to it
See
https://www.thirdgen.org/forums/post...71-post19.html
Maybe read
https://www.thirdgen.org/forums/elec...y-starter.html
Old Jun 18, 2013 | 09:43 PM
Thankx vetteoz i will check on the info you gave me and i will post if it succeded.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
madsv1000
Aug 20, 2015 06:45 AM
