help, cooling system related
Old Jun 19, 2013 | 09:01 PM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
so I have to remove my heads and when I took one off the old crummy gasket fall to pieces and some of the pieces fell into the blocks water paths.
now the question is how do I get those pieces out? the water level is low (from the top anywas) but still has water in the bottom. could I just fill it up and let the pieces flow out with water? any one got ideas?
Old Jun 19, 2013 | 09:07 PM
Re: help, cooling system related
You could try that. Might work, not sure if the gaskets float though. Or, reach down in there with forceps or the like; turn it upside down and shake it; pop the freeze plugs out and reach in that way; take it to the quarter car wash and blast it with the wand; I'm sure lots of other creative approaches could be found.
Old Jun 19, 2013 | 09:21 PM
DARKmj16's Avatar
Engine: 305 tbi
the block is still in the car and I don't have the lift to take it out, and im not gona mess with the freeze plugs. I will try the forceps idea tho, and I have a power washer at home id use lol. thx for the ideas tho.
anyone got other ideas?
Old Jun 20, 2013 | 10:51 AM
DARKmj16's Avatar
Engine: 305 tbi
heres a question, are the waterpump inlets on the block level with the coolant flow tho the block? or does coolant drop down further into the block from the water pump inlets?
Old Jun 20, 2013 | 11:32 AM
They are about halfway down the water jackets, and look right straight at the outside of the cyl sleeves.
Hotrodboba400
Dec 10, 2019 07:07 PM
64goatman
Sep 9, 2015 01:09 PM
Fronzizzle
Sep 8, 2015 12:10 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
