Intake Manifold adapters
Old Jun 21, 2013 | 05:06 PM
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
I went online today and saw a set of intake manifold adapter bushings. I am not sure if these are to be used with specific intake manifolds or if they sell a set of universal ones. The issue is I am considering building a carbed set up for my camaro but the intake I have is for 86 and older heads and I have the 87 and later style.
Old Jun 21, 2013 | 06:23 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Intake Manifold adapters
are you talking about the 4 center bolts being on a different angle? if so, i usually just take a drill bit and wallow them out on the intake. ive cut my own "bushings" or spacers out of pipe or tubing. just put the appropriate angle on one end, and use washers. might 4 longer bolts if you make the spacers too long.
Old Jun 21, 2013 | 08:11 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by redneckjoe
i usually just take a drill bit and wallow them out on the intake. .
Just like the aftermarket were one intake fits both style heads.
All I have ever used is a thick washer to spread the load
Old Jun 22, 2013 | 06:59 PM
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
Hey thanks for all the advice guys...I am in the process of disassembling my engine, this motor was originally a 305 TPI. Would you guys happen to know the sizes of the fittings coming from the fuel lines off the drivers side engine compartment. I am looking to route those lines into a FPR
Old Jun 23, 2013 | 03:32 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
The feed line is 3/8" and the return is 5/16".
Old Jun 23, 2013 | 03:53 AM
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
Thanks watajob, now all I need to figure out is how to get the 5/16 fitting to go into the 3/8 NPT regulator.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Jlanz55
Sep 6, 2015 07:28 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
