Now the car won't start
Car: have a 92 camaro rs...in pieces
Engine: none now...probably 383 stroker
Transmission: none yet
Axle/Gears: none
To understand why I did what I did before I go in depth... https://www.thirdgen.org/forums/tech...r-install.html .........
So I figured maybe the previous camaro had a chip hence I went ahead and threw in the Eprom from the other camaro into the one I'm messin with currently... In doing so the car started and ran fine for about a minute...Then stalled. Now it won't crank and no security light on... Half the gauges are illuminated, when I pull the light switch a different part of the gauges light up. Why can't I start this damn thing? Is it the VATS/pass key theft BS? I've tried leaving the key in the ignition for a while, removing the power off the battery and hookin it back up. NOTHIN. What do I do?
Axle/Gears: none
Re: Now the car won't start
Over 100 views and nothing?
Axle/Gears: none
Problem fixed. Starts and runs.
