Crank no start. engine swap. vats?
Old Jun 26, 2013 | 03:50 PM
Ic3manTow3ry's Avatar
Swapped 89 Iroc 5.7 tpi motor, tranny, engine harness, and ecm into 87 k5 blazer.
I have spark, I have fuel to the rails, and have combustion(spray starter fluid and she'll turn over for as long as I spray)
which leads me to, No power to the injectors. Possibly VATS? I had VATS in the camaro, but I dont have it in my truck. Would the ecm tell the injectors not to have power if VATS is in the prom of the ecm?
Old Jun 26, 2013 | 10:57 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Crank no start. engine swap. vats?
No power to injectors or no injector pulse ; two completely different situations ?
Possibly VATS?
Unless you have a custom tune removing VATS , then it makes no difference what vehicle the ECM is in , it will still be looking for a fuel enable input from the VATS module
before it will pulse the injectors.
If you don't want to pay for a custom tune , then buy something like this to generate the required fuel enable signal
http://www.bakerelectronix.com/products_vats/
Old Jun 27, 2013 | 12:24 AM
I went on a hunch I had after making sure I knew the wiring was't the problem. I pulled the VATS module out of the car, hooked up the wiring that was coming out of the connector to that, except the "security light" and "starter relay enable" wires. cut the ppl/wht and wht/blk wire to the key cylinder and just pressed one wire to each side of my camaro key chip and it started right up. Thanks for the reply thought!
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
djmarch
Aug 9, 2015 05:27 PM
