Oil leak question
Old Jun 27, 2013 | 04:15 PM
1986 iroc z28's Avatar
Car: 89 formula
Transmission: t5
Axle/Gears: open junk
Oil leak question
So my old 383 decided to start dumping oil everywhere, so i tore into it and found the front edge of the pan gasket where it meets the timing chain cover is where its coming from. But heres the kicker, the inner edge of the lower part of the chain cover where it "holds" the gasket has seperated from the cover making a 1/16" gap where the oil was basicly pouring out. My question is why did this happen? And how do i prevent it? I will attach a picture in hopes of trying to explain myself better.
(dont mind the scribbles, that is just covering up the previous crap i wrote, lol)
Old Jun 27, 2013 | 04:18 PM
Car: 89 formula
Transmission: t5
Re: Oil leak question
Originally Posted by 1986 iroc z28
So my engine decided to start dumping oil everywhere, so i tore into it and found the front edge of the pan gasket where it meets the timing chain cover is where its coming from. But heres the kicker, the inner edge of the lower part of the chain cover where it "holds" the gasket has seperated from the cover making a 1/16" gap where the oil was basicly pouring out. My question is why did this happen? And how do i prevent it? I will attach a picture in hopes of trying to explain myself better.
Heres a little more info on the engine this happened to, its a 3970010 block .030 over, 400 crank, head work including 2.02 valves, comp extreme energy cam, and a high volume oil pump. I cant remember the exact cam rates or cylinder head cc's off the top of my head, as i built this engine in 2007 when i was 16 lol
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
drathaar907
Aug 6, 2015 04:20 PM
