87 camaro engine starting
Old Jun 27, 2013 | 06:42 PM
Irocum24's Avatar
Have a 87 Camaro IROC-Z 305 TPI. Last couple days been hard to start. Try to start would just crank second attempt would start following week went on to third attempt then would start. Now car starts up runs for 1-2 secs then stalls start car again starts up and runs. Going to run some sea foam through gas tank see if that helps. Does anyone have idea? Also pump gas once seems to start better, and then car heats up really fast cold to 220 in 2-3 minutes but was also 102 temp outside
Old Jun 27, 2013 | 09:15 PM
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Re: 87 camaro engine starting
unplug the MAF and see how it starts/runs.
Old Jun 28, 2013 | 12:01 AM
TylerrrrrH's Avatar
Car: 1987 IROC-Z Camaro
Engine: 305 V8 TPI
Transmission: 700r4 Automatic
I have the same exact car and the same issues. It's really frustrating. Tonight it took me a long time to get it to start and stay running, when usually it just takes two or three tries.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
92projectcamaro
Aug 6, 2015 01:20 PM
