Performance Timing Options using on an 86 CC Q-jet?
Old Jun 28, 2013 | 12:43 PM
Corellian Vette's Avatar
Car: 1986 Firebird
So I’ve been having fun playing around with my 86 Firebird with the CCQ. It’s been an interesting learning experience and I now feel likeI have it tuned to a place where it’s working really well.
This, of course, leads me to think about tuning for more performance.
I understand (and I’m in the process of) fixing the exhaust restrictions, and I’m going to look over the jetting and secondary opening rate of the Carb itself. I also need to procure a better air cleaner.
The one thing I’m a little stumped about is how the computer controls the timing and what options I have to improve the curve using the stock distributor.
In stock form, I know the distributor is set to 6* BTDC and the computer controls the rest. I also know that if I was tuning a normal HEI with vacuum advance, I would be tuning for a max of ~ 36* at 3000 RPM, with a milder vacuum advance can for highway/cruising and mileage.
What options do I have to improve the timing for performance? How does the computer adjust timing at WOT vs Cruise?
The computer assumes the car is starting at 6* - but does it put a full 36* in at WOT? If not, does adjusting the base timing change that? Can I go up to 10* or even 12* without causing pinging problems?
Love some expertise and experience…
Thanks!
theshackle
Sep 17, 2020 08:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
NBrehm
Aug 25, 2015 11:49 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
