serpentine conversion
Old Jun 28, 2013 | 09:37 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
91 305 tpi and 86 donor tpi engine
im converting my belt drive from serpentine to v belt. I don't have smog or a/c and want to clean up the front of the engine. I have an alternator, power steering unit, clockwise water pump, and the brackets and pulleys from a donor engine. i have a few questions:
has anyone done this and can you post some pics?
can I use my existing power steering pump with the v belt pulley?
how do I rewire the alternator? can I use the connector from the donor and splice onto the harness?
Old Jun 28, 2013 | 11:09 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: serpentine conversion
Why go to V-belt?
Can you do what the Vette L98 guys do ;
make a adjuster for the Alt and use that as the belt tensioner , like on old skool SBC along with a shorter belt
Old Jun 29, 2013 | 01:41 AM
tonys91rs's Avatar
Car: 91 Camaro RS
interesting idea. I see that it would eliminate the pass side bracket all together. which is a start. how is the driver side bracket modified?
Old Jun 29, 2013 | 03:50 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
It's not
All you need is to make or buy an adjustable brace for the Alt so you can tension the belt .
Can be mounted to the head , water pump or front of intake if you have vacant hole there.
Budget scrap metal brace shown at top.
Double rod end shop version below
Old Jul 2, 2013 | 06:25 PM
tonys91rs's Avatar
Car: 91 Camaro RS
if i decide to go in the other direction and use the older alternator, how is it rewired?
Old Jul 2, 2013 | 06:47 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
That would be a question for the Elec Dept
https://www.thirdgen.org/forums/elec.../?daysprune=-1
Linson
Oct 24, 2025 02:00 PM
jrdturbo
Mar 31, 2016 02:58 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
