Caprice not camaro question
Old Jun 29, 2013 | 08:50 PM
Crudsturbo's Avatar
Ok 1991 Caprice 305 TBI system. My brother picked it up for 400 bucks a great deal it needed an ignition switch, a good buffing and turned out super nice for the price. Well after a few days it just up and developed a situation where it would bog down or I guess seem like it was choking out past 1/4 throttle. Well a bud of his said to jump the coolant temp sensor which he put a paper clip from wire to wire at the one on the intake manifold. The car immeadiately stall and now will only run with the pedal to the floor. Also showed him he had on under manifold and explained jumping meant grounding it.....
Question is what damage was done? What possible solutions to his first issue? ? HE changed fuel filter, fuel pressure regulator, plugs, wires, cap, rotor, timing is set right.
Old Jun 29, 2013 | 09:33 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Caprice not camaro question
Start by
https://www.thirdgen.org/forums/tech...s-dumbies.html
and report back any codes you find
Old Jun 29, 2013 | 10:10 PM
Crudsturbo's Avatar
Originally Posted by vetteoz
Start by
No check engine light on but I know all to well that doesn't mean it doesn't have codes. I will be over there tomorrow or either Monday for sure I will post what I find.
Old Jul 2, 2013 | 06:33 PM
Crudsturbo's Avatar
Ok all wanted to report back it was the converter clogged. Opened her up and she is great now! Also had to adjust his detent cable, and the jumped sensor issue was fixed by unhooking the battery to reset the ECM.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
camaro71633
Sep 1, 2015 10:24 AM
redmaroz
Aug 16, 2015 11:40 PM
matthew911
Aug 12, 2015 09:38 AM
