Has anyone used 187 heads on a L69 or other carbed engine ?
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
Wondering if anybody has any experience in this swap. My understanding is that the 187 heads were for TBI and TPI engines so I guess the intake for the L69 wouldn't fit.
If a 187 head is used on a L69, what intake manifold would be needed to work with a q-jet setup?
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Has anyone used 187 heads on a L69 or other carbed engine ?
Those are swirl ports found only on TBI, not TPI, IIRC. In general, most people say their only automotive application is as ballast in the trunk. If you're hell bent on using them, the middle holes on your intake can be hogged out to fit the older style bolt pattern. Be advised, you'll also lose compression due to a larger chamber size.
Compression will be about the same.
You'll take about a 10 - 15% HP hit due to the extremely power-hostile design of those "swirlies".
Not sure in what universe this could possibly ever become A Good Idea.
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
an'88 caprice LG4 i had had the 187s and a q-jet manifold-i don't know if '87 f-body LG4s were 187s/carb,but i'd guess they were.
Car: 1983 G20 Chevy
Transmission: 4L60
One was in a boat and ran 5,000 rpm all day long.
84z96L31vortec
Aug 20, 2017 12:16 AM
theshackle
Mar 5, 2017 06:37 PM
