New Battery Question
Old Jul 2, 2013 | 11:01 AM
Trelane's Avatar
Car: 1991 Pontiac Firebird 3.1 V6
Hey,
I've got a 1991 Pontiac Firebird 3.1 V6 and need to buy a new battery(long story).
I have two problems:
1) I'm in the UK, this seems to make it virtually impossible to buy a side terminal battery that fits (240mm in length when all the batteries are 260mm).
2) I do not know the 'cold cranking' etc amps that is the minimum required for the car.
Please can someone point me where to get a battery in the UK?
Or let me know the minimum cold cranking amps etc required in a battery for the Pontiac Firebird.
I've found a side terminal battery that i can get in the UK with 550 Cranking AMPS, but have zero idea if this is any good.
Cheers,
Mike
Old Jul 2, 2013 | 03:54 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: New Battery Question
Should be plenty for your application. Switching to top posts is also an option as there is enough room.
Old Jul 2, 2013 | 04:11 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
They also have top post to side post adapters available at most parts stores. Even Wal-Mart has them
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
As a general rule, CCA should be double the cubic inches of the engine for stock gasoline powered vehicles. More CCA is never a bad thing. This would put you in good shape at 550CCA.
Old Apr 28, 2014 | 05:27 PM
stue's Avatar
thanks for this thread guys ive been trawling the net looking for a battery for mine,im also in the uk now I know what size to get lol
Old Apr 29, 2014 | 01:59 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Originally Posted by Trelane
Hey,
Cheers,
Mike
Two places I'd start...
1. Pontiac Owners Club UK...they have a web site and a plethora of information for you.
Pontiac Owners Club (UK)
2. Robin Grey at Auto Pontiac in London. Dude fixed my car right up when I had issues and he's got a ton of knowledge and is more than willint to just chat on the phone to give advise.
AutoPontiac
Also....www.Rockauto.com does ship to UK addresses but not sure about batteries.
Hope this helps!
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
redmaroz
Aug 16, 2015 11:40 PM
