dipstick tube changed in 92 camaros?
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
so I broke my dipstick tube and trying to find a new one... the cheapest thing I found was $55!! for the factory black $68 for the cheesy chrome ones and $78 the stainless flexable steel ones! that was crazy so I look for 1991, and pretty much every other year, and they have chrome ones for 14 bucks. -.- so I got a 1991 dipstick tube and sure enough its shorter and the stupid braket is all wrong, looks like a driver side tube, not the passenger side like my rs is.
so what gives?
so what gives?
Engine: 305 tbi
Re: dipstick tube changed in 92 camaros?
both I guess. but im really carious why a 1991 rs dipstick is $14 but the 1992 is $55, and also why they are different.
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
all the 86 and later blocks have the same provisions for the dipstick tube- but they did use different parts for different applications. some of them bolted to an exhaust manifold bolt, some to the bolt in the side of the block... some weren't much higher than the valve covers, some pointed up towards the front of the engine to make it easier to reach in a truck or van... i like the 94-96 Caprice LT1 dipstick and tube, personally.
i think that short one you got was for the 80 and older small blocks..
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Maybe the shop had it labeled wrong ?
All the 1 pce RMS blocks ('87+ ) have the dipstick hole low down on the block by the pan rail ,so a longer tube is needed
2 pce RMS blocks with the drv stick have the hole up top nearer the head ; so a shorter tube
2 pce RMS w/pass side stick ('81 - '85 ? ) I don't have so can't comment on what style stick they have.
maroe624
Apr 16, 2017 08:29 AM
