Check Engine Light! HELP!
Old Jul 4, 2013 | 03:23 PM
Edgarg86's Avatar
Car: 85 Camaro Z28
I have an 85 Camaro z28 tpi I been having a problem with the Check engine light that turns ON when I make any type of stop, and then goes OFF as soon I start accelerating. Dont know what could be causing this, can anyone please help.
Thank you for taking your time in reading my post, hope you guys can help
Old Jul 6, 2013 | 03:34 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Check Engine Light! HELP!
Welcome to TGO!
Since this is a soft fault and goes away, it makes me lean toward a fuel issue meaning running lean/rich. My 84 did this until I got the carb tuned properly after a rebuild First, if you don't have one, get a reader to read the codes it's throwing. Other than that, replace the 02 sensor. They are cheap and easy to replace and can . Second, make sure your EGR isn't clogged. Finally, make sure that your CAT isn't clogged. Any one of these can lead to this code at idle. As the RPM's wind up the engine burns the fuel cleaner, clearing the code.
Also make sure that your injectors are pushing the right amount of fuel because that can cause a lean/rich condition. Alternately, a MAP/MAF sensor or one of the other sensors could be going bad. All in all, it sounds like something rather minor is causing the light, just need to nail down what it might be.
Old Jul 6, 2013 | 05:11 PM
Edgarg86's Avatar
Car: 85 Camaro Z28
Originally Posted by Ozz1967
Welcome to TGO!
Thanks for the response ,
I have tried the code reader but, it does not read any code , in the past year I have replaced the O2 sensor , EGR valve and the CAT just past Smog regulations, this leads me to believe it might be MAP/MAF sensor or the injectors might have to cleaned or replaced.
Old Jul 6, 2013 | 06:09 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Doesn't read at all ( bad connection to computer ?) or doesn't show any codes after connecting ?
Old Jul 6, 2013 | 06:19 PM
Edgarg86's Avatar
Car: 85 Camaro Z28
doesn't show any codes after connecting.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
