Heavy oil smoke on restart
Old Jul 7, 2013 | 02:33 AM
kfairshon's Avatar
From: Maple Falls, WA (5 miles south of Canadian border)
Car: Yellow 85 IROC [Rare 1 of 205 GU6]
Engine: 5.0 TPI(30-over w/forged internals)
Transmission: 700R4 (NASCAR built)
Axle/Gears: GU6 3.42
OK guys, here's the deal. I have a freshly-rebuilt 5L TPI in my 85 IROC. It's been punched out 30 over, refitted with 1.94?/2.02 valves, rollers, dual roller timing gears/chain, fully blue-printed with all forged internals, and high-volume oil pump.
When first start it up and run it everything is fine. However, if I shut it down and then restart it within say, 20-30 minutes or so, oil smoke just rolls out of the exhaust. If I let it sit for a while it's fine.
It did overheat once, pretty bad, after the temp sensor failed. My first thought was failed valve stem seals but it seems like that being a "mechanical" failure would cause rather consistent symptoms.
The other thought is, I can't help but wonder if the high-volume oil pump is overwhelming the capacity of the otherwise stock heads to return the high volume of oil to the crankcase. Maybe a combination of both?
Is it possible that the oil burning is actually trans fluid somehow entering the combustion chamber through the TPI intake? Or, is there even a route for it to do so?
Would a plugged EGR valve cause something like this?
Any thoughts would be greatly appreciated!!!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Stryker412
Sep 20, 2015 06:59 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
Accerrito22
Sep 5, 2015 09:34 PM
