Power to distributor, but no spark.
Old Jul 7, 2013 | 10:13 AM
burn0ut305's Avatar
Car: z28
Transmission: pro built 700r4 (road racing kit)
like i said in the title i have power to my distributor but no spark. Everything is new, so this really is frustrating. I replaced the control module first because that was the only thing in my distributor that hasn't been replaced in the last year. put everything back on and nothing.
took everything back a part and found that my new coil had shorted out (wires where burnt). thinking that was my problem i got a new one and still i have no spark. the cap is new, the coil is new, and now the control module is new.
where should i go from here? just try a new distributor all together?
Old Jul 7, 2013 | 04:03 PM
ex-x-fire's Avatar
Re: Power to distributor, but no spark.
You've got a hei type dist. on there? Remove the coil cover & test for full 12v at the red (+ side) with the key on & flashing power on the other wire (-) while cranking the engine.
Attached Thumbnails Power to distributor, but no spark.-455x363xhei_coil_ground_center_term_jpg_pagespeed_ic_ygdtqdsrrn.jpg
Old Jul 7, 2013 | 09:43 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by burn0ut305
no spark.
Work through the No spark tests
http://easyautodiagnostics.com/gm_ic...n_module_1.php
Caspar
Jun 19, 2016 11:19 PM
sailtexas186548
Aug 24, 2015 10:11 PM
stalkier
Aug 21, 2015 01:54 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
