comp cams xfi 268 and 113 heads
Old Jul 7, 2013 | 11:38 AM
PontiacPower87's Avatar
Car: 1987 GTA
Engine: NONE
Transmission: T5-WORLD CLASS
Axle/Gears: 9 BOLT- 3.45
I'm in process of building 350 and need help with the heads. I have already purchased a used set of 113 heads and comp cams hyd roller 268 xfi cam. I need help determining what valve springs to run. Can I use the comp cams 918 beehive springs without machine work to the heads? If not what needs to be done? Is there a better/cheaper way to handle lift of this cam? Trying to do this on a budget with least amount of work possible. BTW I plan on running stock rocker arms with 1.5 ratio instead of the 1.6 the cam is rated at.
Old Jul 7, 2013 | 08:41 PM
Car: 1987 GTA
Engine: NONE
Re: comp cams xfi 268 and 113 heads
Can't anyone help around here?
Old Jul 8, 2013 | 09:21 AM
JaBoT's Avatar
The 918's should fit. Just make sure you have the correct pressures when installed. That's the most important thing.
Old Jul 8, 2013 | 10:39 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I think maximum lift on 113's without machining is .525
The XFI with 1.5 rockers is more than that.
Old Jul 8, 2013 | 10:49 AM
JaBoT's Avatar
Yea I just checked and there is a good chance it will hit the guides.
Besides that is a lot of lift for those heads
Old Jul 8, 2013 | 11:05 AM
Car: 1987 GTA
Engine: NONE
Ya I believe I need to clearance the valve guides but not machine the valve spring pockets.......is that correct?
lt500r55
Sep 1, 2021 01:30 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
theurge
Aug 21, 2015 12:46 PM
