No spark and some other symptoms
Old Jul 8, 2013 | 11:23 PM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
Long story short... car sat for a year...
Drove it from it's parking place to my house, was running it charging the battery when it apparently shut off (I wasn't there). I replaced the battery because it was bad but now I have no spark.
According to the manual I should have 10+ volts on the C and + connectors from the Ignition Control Module with the ECM connector disconnected. I have none on one, and residual on the other.
2 guys I talked to said my ICM is probably toast.
The other 2 symptoms are my oil pressure guage was 0 when I first revived it,.. now it's maxed... as is my tach (they are kind of stuck on each other). I also disconnected the tach lead from the coil and the tach is still maxed.
Is this related? or separate?
Rich
Old Jul 10, 2013 | 11:05 PM
waltersb's Avatar
Re: No spark and some other symptoms
Help please
Rich
Old Aug 18, 2013 | 06:16 PM
waltersb's Avatar
Ok... pulled my distributor cap off.. it's not great... and the ICM...
and this is what I'm left with... is it removable? or am I pulling the whole shaft?
rich
Old Aug 18, 2013 | 06:59 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Replace the distributor. With that amount of rust, your ICM will never get correct readings.
Your oil pressure switch probably needs to be replaced also.
Old Aug 18, 2013 | 07:50 PM
waltersb's Avatar
Do I need to replace the ICM too? Or did it just give up because of all this other stuff?
Is it testable? Oil pressure switch gets accessible after I take the distributor out.
Rich
Old Aug 18, 2013 | 08:54 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Rich
at this point I would do "A" check EVERY thing having to do with it starting and running under the hood. "B" pray to your diety of choice that it starts and runs
Old Aug 18, 2013 | 09:02 PM
waltersb's Avatar
The irony is it ran mostly fine up until it quit... no real issues...
Old Aug 25, 2013 | 07:31 PM
waltersb's Avatar
ok, i have the distributor out... wtf is the oil pressure switch
Old Aug 30, 2013 | 09:33 PM
Mr Froman's Avatar
Oil pressure switch is on the driver side, above the oil filter. ICM comes with the distributor.
Old Aug 31, 2013 | 12:47 AM
waltersb's Avatar
The manual I have lists it behind the driver side valve cover... but I have a car that's 1/2 way between an 88 and an 89... so I'll look in the other place... Looks like I can put the dist in. ... Wanted to make sure I knew where the oil pressure switch was first. Kind of lucky? the ICM comes with the dist.. the dist was $135. The ICM was going to be $110 by itself...
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
