Surging idle, stalling
Old Jul 10, 2013 | 12:00 AM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
Finally getting the car up and running after sitting a year. I replaced all the fuel, injectors, spark plugs and oil.
Well the car runs fine when driving but at idle the rpms vary between 500-1000 RPM and sometimes when it falls to 500 it just dies. I have to two-foot it at lights to keep it from stalling.
Ideas on where to start looking?
Old Jul 10, 2013 | 02:58 AM
dustnx's Avatar
Car: 1989 Firebird
Engine: 350 TBI
Axle/Gears: Stock
Re: Surging idle, stalling
I had similar problems when I was doing a full engine swap on my firebird, which sat for probably 6-8 months before being ready... but it ended up being the line to the fuel pump inside the tank. It had rotted and gotten a hole in it, might be something to check.
Old Jul 10, 2013 | 08:43 AM
Car: 92' RS
Engine: LO3
That was the source of the problem with it a couple years ago. I dropped the tank then and replaced the pump and soft line splice to the hard line. I had let it sit with low fuel and that little rubber splice line split open.
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
greenyone
Sep 8, 2015 08:41 PM
rjcme
Sep 5, 2015 01:23 PM
