Removing Passenger side valve cover
Old Jul 17, 2013 | 08:07 AM
85Irocbuild's Avatar
Car: 1988 Gray Iroc
I am currently giving my engine a slight tune up and replacing the belt, spark plugs, and wires. However, I've noticed that both of my valve covers are leaking a small amount of oil. I replaced the drivers side with a new gasket. However, the passenger side looks like a bear to even get to. How do I go about getting to the valve cover on the passenger side? There is so much clutter in the way, I do not know how or what to remove to get to the cover.
Old Jul 17, 2013 | 08:37 AM
ghost91's Avatar
Car: 1991 Camaro Z28
Re: Removing Passenger side valve cover
Easiest thing is to remove the heater hoses that run parallel with it. You can get the coil out of the way too since the bracket for it is kinda in the way. After that you should be in the clear.
Old Jul 19, 2013 | 07:25 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Heater hose and coil, check. Ignition wires and vacuum tubes as well. A.I.R. diverter valve should be removed. Also, the A.I.R. tubes temporarily need to be bent up out of the way.
Old Jul 19, 2013 | 07:29 PM
ghost91's Avatar
Haha...i totally forgot about the AIR since i dont have it anymore... oops
Old Jul 19, 2013 | 10:29 PM
Car: 1988 Gray Iroc
Removed the valve cover earlier today and replaced the gasket. It sure was a pain! Thanks for all of the tips, they were helpful.
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
Street Lethal
Aug 14, 2015 08:25 PM
mustangman65_79
Aug 8, 2015 01:18 AM
