worked 993 heads vs vortecs?
Old Jul 19, 2013 | 08:36 PM
87fbodyy's Avatar
Car: 87 iroc-z
Engine: 355 tpi
Axle/Gears: 4.10
hows it goin fellas, I got a couple questions.. 1- I was wondering what kind of numbers you guys think ill be putting down on the dyno next week, motors a 355 , flat top pistons , comp xe274 cam , mexico 993 heads 2.02/1.6 valves with 76cc chambers , .015 thick head gaskets and a tpi set up on top with 40lb injectors. and 2 - I was thinking about edventually sending my 993s out to be built, would I be better of starting with a set of vortecs or just build the 993s? thanks, justin
Old Jul 19, 2013 | 08:40 PM
Re: worked 993 heads vs vortecs?
993 is trash. There aren't a whole lot that are any worse.
How is this even a question?
Only issue would be, if your car is TPI, the intake won't bolt to Vortec heads.
Old Jul 20, 2013 | 03:06 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
If you want similar performance to Vortec heads, but still want to be able to use your TPI, look into the Dart Iron Eagle SS 165cc heads.
http://www.aeroheadracing.com/chevrolet-heads/
CHP magazine did a test of those heads against a few others.
They claim to be 165cc intake runners, but measured out to 178cc.
They didn't flow as well as Vortecs, but in real world numbers, they did pretty well against the Vortec heads. By the time all of the extras are added into the cost, Vortec heads aren't cheap anymore.
Dart Iron Eagle S/S Heads
Vortec Heads
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
