zz4 heads help!!
Old Jul 29, 2013 | 04:05 PM
MonneyMann1's Avatar
Car: 91 camaro
Transmission: T5 Manual
zz4 heads help!!
I have a 350 mexican block in my 91 camaro. I found someone selling zz4 heads but im unsure if they will work on this motor. any help would be great. Thanks
Old Jul 29, 2013 | 04:15 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: zz4 heads help!!
The ZZ4 is a 35O so they should bolt on.
Old Jul 29, 2013 | 05:14 PM
Car: 91 camaro
Do you know if my Headman shorty headers and Edelbrock perfromer tbi intake will bolt on?
Old Jul 29, 2013 | 07:19 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
casting # on heads?
Your 91 intake will require slotting of the 4 center bolt holes to suit the old style bolt angle used on the ZZ4 heads ( no biggy )
Headers will bolt on fine but may not seal correctly because a true ZZ4 head has D shaped exh port
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
