I need a timing light that works with a MSD 6al, what to get?
Old Jul 30, 2013 | 01:21 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I have heard that some lights don't work with the 6 al I am looking at getting this one,
http://www.summitracing.com/parts/ino-5568/overview/
Equus 5568 Pro-Timing Light with Tool Case : Amazon.com : Automotive Equus 5568 Pro-Timing Light with Tool Case : Amazon.com : Automotive
Old Jul 30, 2013 | 02:24 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: I need a timing light that works with a MSD 6al, what to get?
I have this
http://www.summitracing.com/parts/an...FWIV7AodowgACQ
Seems to work just fine with my MSD 6AL
Old Jul 30, 2013 | 04:53 PM
BLACK Z's Avatar
Car: 86 Z28
I would like one with a RPM Read out.
Old Jul 31, 2013 | 02:18 PM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
A plain old timing light with rotary timing dial works. and not too expensive.
I had a nice digital model with RPM read out, it worked too but I ran over it at the track years ago
I did not want to spend the money for another digital one.
Old Aug 1, 2013 | 12:09 AM
BLACK Z's Avatar
Car: 86 Z28
Maybe a dumb ? but how do you guys know what your rpms are echecking the timing? You have a helper?
Old Aug 1, 2013 | 06:24 AM
midias's Avatar
A helper or an external tach.
Old Aug 1, 2013 | 07:59 AM
BLACK Z's Avatar
Car: 86 Z28
I have a few external tachs for my chainsaws and small engines, I thought about that after I posted.
How is that actron light posted above, can't find many reviews about it.
Old Aug 1, 2013 | 08:12 AM
midias's Avatar
I like mine. Seems plenty bright, the pickup is made out of metal and it has lasted about 2 years. I have used better but they were all at least $100, for the price I have not found anything better.
Old Aug 1, 2013 | 08:37 AM
BLACK Z's Avatar
Car: 86 Z28
Have you tried it against any other light to see if the readings were the same with the 6al?
Old Aug 1, 2013 | 08:40 AM
midias's Avatar
The only other light I have is non adjustable but they both had the same 0
Old Aug 1, 2013 | 09:33 AM
midias's Avatar
All these are listed as multi spark capable
http://www.summitracing.com/search/p...compatible/yes
Old Aug 2, 2013 | 02:20 PM
BLACK Z's Avatar
Car: 86 Z28
Yeah I had researched them before, if you do a google search a lot of them come up as not working with MSD boxes, I ordered a Old sears light off the internet, which I researched and they are sup to be the most accurate light out there for msd.
Old Aug 5, 2013 | 09:08 PM
midias's Avatar
I ordered a set of timing tapes from MSD for $5. I plan on testing my adjustable light vs my static light.
Old Aug 5, 2013 | 09:17 PM
skinny z's Avatar
I've had mine for years (Craftsman from Sears) and no issues to report with the 6AL. I like the dial back feature.
Old Aug 5, 2013 | 09:34 PM
BLACK Z's Avatar
Car: 86 Z28
I got one that doesn't have a dial, My Balancer is degreed, they say the Model Light I Got is very accurate and is the one MSD recommends if you don't have there.
Old Aug 5, 2013 | 09:38 PM
skinny z's Avatar
I like the recommendation from MSD. I've heard a story or two that the dial back light (as I have) isn't suited to a MSD system. I've experienced no trouble when comparing it to other timing lights I have but it's something I've wanted to investigate.
Sounds like you're good to go.
Old Aug 9, 2013 | 08:56 AM
BLACK Z's Avatar
Car: 86 Z28
Both Sears/Craftsman old time Lights seem to work and both read the same.
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
justin57
Aug 20, 2015 07:05 PM
Omega
Aug 10, 2015 12:46 PM
Thirim
Aug 9, 2015 06:19 PM
