serpentine kit
Old Aug 2, 2013 | 05:43 PM
2004chevyman's Avatar
Car: 1986 camaro
Engine: 2.8
Transmission: 700r
Axle/Gears: 243
serpentine kit
i have a small block 327 engine ,and i want to do away with the v-belts and go with the serpentine kit ,now my question is will i jave to buy new or is there another engine that the serpentine kit will fit my 327,and if so what make and model and year ,thanks for any help or info that anybody can give
Old Aug 2, 2013 | 08:47 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: serpentine kit
I don't know about a direct bolt on to a 327(an engine last installed in early build '69 cars-accessory holes on the heads could be different)but you could salvage the parts for the swap from an '88-~'95 SBC or 90*v6 chevy car such as thirdgen ,caprice or possibly light truck.If you want to omit the smog pump or A/C,you could just get the important pulleys and the water pump and custom fab the rest of the setup if you have the capability
Old Aug 2, 2013 | 11:19 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: serpentine kit
The factory style heads from an "original" style 327 from the 60's won't have the mounting holes for the serpentine set up. If you have modern heads (anything after 1980 or after market), then you'll have the mount holes and you can swap in the serpentine set up.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Pinguiclia
Oct 12, 2015 04:47 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
