What is more likely to cause popping on Decel, retarded or advanced timing?
Old Aug 4, 2013 | 07:12 AM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I am chasing a rumble/pop in the exhaust on decel, would either advanced or retarded timing on decel cause this cond? the only thing that seems to stop it was with the old computer controlled q jet and hei was when I unplug the 4 pin connector that you unplugged to adjust timing, if i left it un hooked it would not pop but also didn't run right power wise.
I now have a holley 650 dp and MSD Dist, it still does it but not as loud.
Old Aug 4, 2013 | 08:42 AM
Adams Z's Avatar
Re: What is more likely to cause popping on Decel, retarded or advanced timing?
Leaks in the exhaust system tend to be the biggest problem. On decel it allows fresh air to enter and cause the rich mixture to explode.
Old Aug 4, 2013 | 10:01 PM
BLACK Z's Avatar
Car: 86 Z28
Exhaust is sealed tight, I used a Smoke machine to check this.
RazorN8
Jan 7, 2022 11:44 AM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
cstrobel65
Aug 15, 2015 10:19 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
Thirim
Aug 9, 2015 06:19 PM
