Dynamic Compression Ratio - CALCULATION PROBLEMS !
Old Aug 4, 2013 | 06:59 PM
ez2cdave's Avatar
Car: 1989 Camaro IROC Z
Engine: 383, soon to be an LS Stroker
Transmission: 700R4 - Switching to 4L80E
Axle/Gears: 10-Bolt/3.42 will be Moser 12-Bolt
I've been reading and learning about DCR and have run into some things that are very frustrating.
(1) Some Cam Manufacturers list their Cam Specs at .006" lift, while others specify .050" lift.
(2) Some online DCR Calculator programs say to take the .050" figures and ad 15 degrees to them and plug them in, while others say this is inaccurate because the Ramp Rates aren't known.
(3) MANY of the online DCR Calculator programs give DIFFERENT answers from each other
These are the ones I've been playing around with, in no particular order . . .
http://www.uempistons.com/calc.php?action=comp2
http://www.projectpontiac.com/ppsite...tio-calculator
http://www.empirenet.com/pkelley2/DynamicCR.html
http://www.tbucketeers.com/threads/d...culator.12683/
https://docs.google.com/file/d/0B7Vt...Ums/edit?pli=1
This is very frustrating . . . Is there an ACCURATE Dynamic Compression Ratio Calculator online ?
Thanks, in advance !
Old Aug 4, 2013 | 08:21 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Dynamic Compression Ratio - CALCULATION PROBLEMS !
The Kelley one is the only one I have found accurate.
Old Aug 4, 2013 | 08:57 PM
Damon's Avatar
They're all a bit of guesswork, in my opinion. In theory, dynamic compression is the compression ratio as measured from the moment the intake valve stops having any meaningful amount of flow past it. Now, if you know where that happens and at what point on the cam that exact lift is achieved, you're in high cotton. But unless you are an engineer with very specific knowlege of the cam and cylinder heads, you don't know what you need to make a truly accurate measurement. So you run some on line calculators and hope for the best.
And for the record, different cams can be rated at different advertised duration lift event points. .006 .004 .001 and, believe it or not, .000 (some GM cams)!! It's all over the map.
Old Aug 4, 2013 | 10:42 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
That's really difficult I think to get completely accurate considering we can have two identical cams if you eyeball the specs, but they're ground completely different... which would in turn affect your compression. You see a lot of cams rated the "same" at .050 figures, but that doesn't tell you what happens before/after those numbers of measurement... which obviously has a lot to do with it. I suppose it's potentially possible to get all those measurements and then make a prediction accordingly, but you'de most likely end up making an average in some way or form would be my guess.
I'd honestly like to know more about this also. This would probably be a question for YellowBullet, heh.
Old Aug 4, 2013 | 11:44 PM
ez2cdave's Avatar
Do you think they tend to err on the "high side" or the "low side" ? Or, are they "all over the place" ?
I'm not comfortable using "guesswork" . . .
Old Aug 4, 2013 | 11:47 PM
1gary's Avatar
http://www.crankshaftcoalition.com/w...pression_ratio
Read the part about the specs not being well known and how to figure it out.Btw one author of this is Techinspector 1 who is one of forerunner in math calculations for high performance.
Old Aug 4, 2013 | 11:50 PM
ez2cdave's Avatar
How were you able to verify your DCR, after the motor was assembled, and compare it to the Kelley predictions ?
Old Aug 5, 2013 | 10:30 AM
1gary's Avatar
PM sent.
Old Aug 5, 2013 | 10:56 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Use the kelley one
Do not use .050 plus 15
Use seat values whether they are at .004 or .006. That is accurate enough.
If you dont know these ask the cam manufacturer.
Or measure it with a degree wheel and dial indicator
Verify by doing cranking compression check. Generally under 210 psi is what i have seen as a upper limit for pump gas but it could vary
Old Aug 5, 2013 | 11:11 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
http://www.proracingsim.com/purchasejac2.htm
Desktop Dyno 5 has all the math you want / need.
hours of engine building and dyno fun for 50 $
then you can test them in the 1/4 or 1/8 mile
using Desktop Drag 5 for another $50 bucks.
I did this years ago, scary how accurate it can be..
What The DeskTop Dyno Can Do:
Build And Test Virtually Any 4-Cycle Engine
Test Engines Speeds From 1000 to 14,500 RPM
Instantly Switch Between US & Metric Units
Find The Best Parts For Street Or Racing Applications
Use QuickIterator™ To Run Automatic Testing!
Use Several Built-In Calculators For Engine Analysis!
Easy Component Selections, Just Point And Click
Test Alternate Fuels And Nitrous-Oxide Injection
Test Any Air/Fuel Ratio
Combustion-Chamber Modeling
Auto-Scaling Power, Torque, Pressure Curves
Display And Print Components And Color Graphs
Test Carburetors/Injection, Stock & Racing Manifolds
View And Print Engine Pressures, Efficiencies
Use Built-In Advanced Calculators (Cam, Airflow)
•Plus Automatic Updates Over The Web!
Tune These Key Engine Components:
Bores (2- to 7-inches) Strokes (1.5- to 7-inches)
Number Of Cylinders (1 to 12)
Intake And Exhaust Valve Sizes
1, 2, Or 3 Valves Per Port
Modify Valve Event Timing, Valve Lift
Model Lobe Acceleration For Intake And Exhaust
Change Individual Valve Opening And Closing Events
Change Lobe Centerlines And Durations
Intake/Exhaust Port Design And Modifications
Wedge, Canted, Hemi, And 4-Valve Heads
Flow Data Models Any Cylinderhead
Up To 7000cfm Peak Induction Flow
Any Carburetor (multiple or single) or Fuel Injection
Intake Manifold And Exhaust Systems
Compression Ratio From 6:1 to18:1
Various Fuels, Including Gasoline, Methanol, More
Any Air/Fuel Ratio From Max Power to Max Mileage
Nitrous-Oxide With Gasoline And Methanol
•And Even More Is Possible With DeskTop Dyno5!
LOL
Old Aug 5, 2013 | 01:00 PM
ez2cdave's Avatar
Hmm . . . So, I take it that program is a "good thing" ? LOL !
beastin91rs
Oct 9, 2015 07:38 AM
fasteddi
Sep 2, 2015 10:29 AM
gixxer92
Sep 1, 2015 04:32 PM
dyeager535
Aug 28, 2015 08:10 AM
