Code 43
Car: 1988 Formula
Code 43
Posted first on Jaysome's thread but thought I'd make my own.
Greetings!
Rebuilt stock 305 with just a hollowed out cat that came when i got the car. prev owner said the same symptom that i am having happened and that is what her " mechanic" did(blow out the cat) to fix. it ran just fine for a good while but then going up a hill one day, it lost power(timing retard/advance?) and the check engine light came on. checked the code and it came out to 43. I pull over, shut it down, wait for a few, and then start it up and checklight goes away. if i get on it again, it does the same.
now it happens all the time when trying to accelerate just going up slight grades or just getting on it. replaced the knock, coolant temp, and fan switch(connector had broken also and was just crammed in there).
Any thoughts would be much appreciated. thanks for reading.
Greetings!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Car: 1988 Formula
Re: Code 43
40 views and 1 reply and the link doesnt work! i feel like im close to the answer but now its taken away!
can i get a hint at least?
or maybe the site is down for a bit. i'll try later. Thanks TunedPerformance!
