cam size
Old Aug 11, 2013 | 01:23 PM
shepherd1's Avatar
Car: 1992 pontiac formula 1979 TA
Engine: 305 4now and a 519 poncho
Transmission: 700r4 and a th400
Axle/Gears: 3.08 and 3.73
cam size
Anyone know how big of a cam you can go with stock tbi CPU before having problems. I have a 92 formula with a 305 tbi and want to put in a comp cans big ***** thumper in it.
Old Aug 11, 2013 | 06:33 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: cam size
That's definitely not going to run well. I don't recommend the thumpr cams in general. They're all sound and very little performance in return. If you want a cam you should get one custom ground for your application.
Old Aug 11, 2013 | 07:36 PM
Re: cam size
Depends on your definition of "problems"; as well as, what else you're willing to change at the same time. (valve springs would be an ABSOLUTE MUST; it may involve machine work as well)
Then....
How good are your PROM burning skillz?
If you're like most people who would ask a question like that, better stick with something AHELLUVALOT eeeeezier to get the rest of the car to work with, than that.
If you've just GOTTA change the cam, I'd suggest something more along the lines of the "302" grind. http://www.summitracing.com/parts/cca-08-302-8
Old Aug 11, 2013 | 08:33 PM
shepherd1's Avatar
Re: cam size
Then....
I can't do CPU work, I run 99.99% old school stuff. I just picked this 92 up for cheap and want a nice sounding cam lope to it. Or I have an extra pontiac 400 sitting around might put that in it. I know when I had a 4th gen formula there was a place here in Ohio that redid CPU for cam swaps. I just can't remember their name.
toronto formula
Nov 10, 2015 06:17 AM
gta90
Sep 15, 2015 04:00 PM
bamaboy0323
Sep 3, 2015 06:07 AM
gixxer92
Sep 1, 2015 04:32 PM
knight72
Aug 10, 2015 09:32 PM
