wrapping cold air intake?
Old Aug 14, 2013 | 07:46 PM
haro_is_king's Avatar
Car: 1989 camaro iroc-z
Engine: L98 350 5.7 bored 0.30 over
Transmission: 2400 stall lockout
i have a custom cold air intake, the egr stuff has been removed so the tubing and cone run to the drivers side. the cone sits where the egr canister,etc. was, the metal ducting sits on the top radiator hose. do you guys think there would be any benefit to wrapping the ducting with turbo wrap to keep the air and the tube nice and cool? thanks !
Old Aug 14, 2013 | 08:26 PM
powerdreams's Avatar
Car: 1987 camaro
Engine: 5.7 vortec
Re: wrapping cold air intake?
I would say no benefit.
Old Aug 14, 2013 | 08:37 PM
The EGR is a little valve that sits on top of the intake; looks kinda like a little UFO.
Not a good place AT ALL for anything to do with the air duct tube. Wrapped or no.
Doesn't sound like you're headed in the right direction.
Old Aug 14, 2013 | 09:41 PM
woops....not the egr but all the smog stuff has been removed and i believe there was some sort of canister located next to the radiator on the driver side. sorry about that but anyway where that canister was, is where my k&n cone filter sits and the tubing is on the upper radiator hose. i thought maybe keeping that tubing as cool as possible (with all the under hood radiant heat) would keep the air going in the throttle body cool = better.....sorry again for the misunderstanding.....maybe ill snap a pic
Old Aug 14, 2013 | 10:10 PM
NuklearFusion's Avatar
Car: 1987 Trans Am
Engine: L98 350
Axle/Gears: 373
I made the mistake of gutting my air box long ago and have the air filter sitting next to the canister. My only saving grace was to route a hose on the top of the filter to an area in the fender for cooler air. If you can't go back to the stock air box, try looking for a heat shield for the air filter. I know that Spectre has one for their filters and is around $30 bucks. It covers one half of the filter (best to put on the top of the filter when the filter is lying on it's side).
Old Aug 14, 2013 | 10:29 PM
thanks man, i have been wondering if i could just get a shield like alot of the newer cars have for their cold air kits but could not find one. yeah my canister is gone so the rubber end of the cone touches the empty tray over there....thanks again ill have to look up that shield!
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
