Car won't start :(
Old Aug 15, 2013 | 12:37 AM
HowDoIDriveStic's Avatar
Car: 1983 Chevrolet Camaro Z/28
Engine: 383 Stroker
Axle/Gears: Posi/3.73
Car won't start :(
First, a bit of background. Ever since I've had this car (83 Z28 383 Stroker) it has cranked really slowly but has started every time. But last night when I tried to start it to leave work, it cranked real slow and then stopped and all my lights went out. I had a buddy jump me and then when I turned the key I just got a click. We then tried push starting it - to no avail. Any ideas?
Old Aug 15, 2013 | 02:55 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Car won't start :(
I had a buddy jump me and then when I turned the key I just got a click. ?
Check your 2 main battery cables from the battery to the starter and block / frame.
Remove / clean / tighten
Old Aug 15, 2013 | 08:42 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Lights going out means that your starter motor is pulling all the current.
Which could mean that your battery is too far gone or that your starter is stuck for some reason.
"Click" means that the starter solenoid can't get the starter motor to do its work, so perhaps that one's fried, too.
After going through vetteoz' suggestions, think about pulling and/or replacing the starter motor.
Old Aug 16, 2013 | 06:10 PM
Engine: 383 Stroker
It ended up being a bad connection to the positive terminal on the battery. I got lucky, the guy who towed it home from work was also a Chevy guy, and wanted to look around under the hood just for fun. Saved me $120
Old Aug 16, 2013 | 08:12 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
So I was wasting my time telling you where to look first to sort your problem?
Old Aug 16, 2013 | 11:51 PM
Engine: 383 Stroker
No man you were right. I just hadn't had time to look at it. My car was stuck at work (45 min away). I planned on checking all of that stuff when I got it home anyways.
Thank you for your help
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
