will a felpro 1094 head gasket work on my engine
Old Aug 15, 2013 | 04:27 PM
89stkformula's Avatar
Car: 1989 formula firebird
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
I have a zz1 crate engine bored to a 355 with afr 180cc head and was wondering if the felpro 1094 would work? My engine is a 1991 and the guy at napa says the gasket will only fit up to 1985 sbc. With my engine being bored over .30 and the gasket is for standard bore 4.100. Any advice would help greatly. Just so you know I am running dished piston so clearance should not be a real issue.
Old Aug 15, 2013 | 06:37 PM
Re: will a felpro 1094 head gasket work on my engine
Standard bore = 4.000
I hope yours isn't bored .30"; that'd be all the way through the cyl wall and halfway through the water. Let's hope it's the more standard .030".
Those steel-shim gaskets aren't known for long and happy life ANYEHRE BUT an absolutely PERFECT finish on both the block and head deck surfaces. And even then, .... I wouldn't run em. Too much maze, not enough cheeeeeeze.
Old Aug 15, 2013 | 08:20 PM
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
thanks you for the corrections. Have you ever run the 1094 gaskets?
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
